mosh te ir kaads gudrs cilveeks kursh var pateikt vai sitaads joks straadaa vai nee
Highway radar jamming by The Jolly Roger
Most drivers wanting to make better time on the open road will
invest in one of those expensive radar detectors. However, this
device will not work against a gun type radar unit in which the
radar signal is not present until the cop has your car in his
sights and pulls the trigger. Then it is TOO LATE for you to slow
down. A better method is to continuously jam any signal with a
radar signal of your own. I have tested this idea with the
cooperation of a local cop and found that his unit reads random
numbers when my car approached him. It is suprisingly easy to make
a low power radar transmitter. A nifty little semiconductor called
a Gunn Diode will generate microwaves when supplied with the 5 to
10 volt DC and enclosed in the correct size cavity (resonater). An
8 to 3 terminal regulator can be used to get this voltage from a
car's 12v system. However, the correct construction and tuning of
the cavity is difficult without good microwave measurement
equipment. Police radars commonly operate on the K band at 22 ghz.
Or more often on the X band at 10.525 ghz. most microwave intruder
alarms and motion detectors (mounted over automatic doors in
supermarkets & banks, etc.) contain a Gunn type
transmitter/receiver combination that transmits about 10 kilowatts
at 10.525 ghz. These units work perfectly as jammers. If you
cannot get one locally, write to Microwave Associates in
Burlington, Massachusettes and ask them for info on 'Gunnplexers'
for ham radio use. When you get the unit it may be mounted in a
plastic box on the dash or in a weather-proff enclosure behind the
PLASTIC grille. Switch on the power when on an open highway. The
unit will not jam radar to the side or behind the car so don't go
speeding past the radar trap. An interesting phenomena you will
notice is that the drivers who are in front of you who are using
detectors will hit their brakes as you approach large metal signs
and bridges. Your signal is bouncing off of these objects and
triggering their radar detectors! HAVE FUN!
