Tehniska rakstura diskusijas
Arc
Post by Arc »
Kāds nezin kādu vietu, kur var pa sakarīgām naudām sametināt? Man grīdu vajag pasažiera pusē pie kājām sametināt, kaut kur uzrāvis esmu..
ramex
Post by ramex »
Arc wrote:Kāds nezin kādu vietu, kur var pa sakarīgām naudām sametināt? Man grīdu vajag pasažiera pusē pie kājām sametināt, kaut kur uzrāvis esmu..
uzšķērdi ??? :shock:
H6
Arc
Post by Arc »
Nu gan jau tur nebija baigi daudz ko uzšķērst - jau bija parūsējis un kaut kur uzplēsu.
Kur lai fiksām dabon šādu trubu?
Diametri - 60 un 70 :roll:
Reāli vajag prekš Raivja S2. Moš kāds zin kur var visu kitu meklēt :roll:
Post by ParaTr00per »
autofavoriitaa pie juurmalenes sky nau?
kā teica pārdevējs - visirslikti ar trubām
nav nekā :D
Viitols
Post by Viitols »
Lambertino wrote:Kur lai fiksām dabon šādu trubu?
ebay.co.uk :naac:
vieniigi fiksaak par paaris dienaam nebuus!
DD nevarētu būt!? :roll:
vairis
Post by vairis »
Man ir šāda, 70mm->63mm, ir vēl 2as 90° 63mm trubas, pseido alu 90° līkums 63mm :roll:
palasiijos par understeer nobeigshanu sheit
http://www.pistonheads.com/gassing/topi ... 0&f=71&h=0
cpas - you need to accept that understeer is built in at the factory with the bumpsteer they include as a default characteristic (like nearly all manufacturers these days).
I've spent 8 years (and way too much money ) messing about with my classic to get it the way I like it. I would recommend approaching it in the order;
Decent rubber all round (no point scrimping)
Proper geometry set-up (Prodrive setting are better than std, but people like PowerStation or TSL will do you custom settings with more castor)
Bumpsteer removal
Uprated ARBs/bushes/droplinks
Antilift kit
Eibach sports springs, or if affordable, coilovers with adjustable platforms (I use ASTs currently)
I would suggest getting camber bolts fitted so that you have proper adjustability on the rears.
wtf ir bumpsteer un Antilift kit ?
theone2be
Post by theone2be »
DeeCee wrote:palasiijos par understeer nobeigshanu sheit
Bumpsteer removal
Antilift kit
Moš kkas no šī palīdz:
Definitions of Bump Steer:
* A steering effect resulting from toe or camber changes as the suspension moves up and down.
http://www.tireboys.com/expert_lexicon.htm
* The change in a tire's camber and toe-out caused by hitting bumps. In incorrectly lowered trucks it may occur.
http://www.jcscoops.com/faq/definitions.php
* Also called toe steer, bump steer is the change in toe-in as the suspension moves through its full range of travel; some change is unavoidable due ...
http://www.motortrend.com/features/arch ... index.html
* The ill-effect a fully compressed damper has on steering through turns. Referred to as such because often times when a damper is fully compressed, it is against its bump stop. When this point is reached, neither the damper nor the spring can do it’s job, usually causing loss of grip. ...
users.zoominternet.net/~tworx7s/Auto%20 ... ssary.html
* Bump Steer is the term for the tendency of a wheel to steer as it moves upwards into jounce. It is typically measured in degrees per metre or ...
en.wikipedia.org/wiki/Bump Steer
Ecku vienam no mūsējiem ir vajadzīgs labs elektriķis kurš salabotu elektronisko spidometru :arrow: viewtopic.php?f=27&t=9806&start=100" onclick="window.open(this.href);return false;
Nav kādam padomā, kāds tiešām labs elektriķis kurš saprot ko dara, nevis var salodēt tikai vadiņus kopā un saslēgt spuldzītes virnē!
Respektīvi vajadzīgs elektriķis ar gudru galvu :aljo:
Man arī noderētu elektriķis un arī spidometra labošanai.
E36 bākā rodas vakums! Zinu, ka ir k-kāds vāstiņš, kas to nepieļauj, bet man šis vārstiņš vizdrīzāk ir kaput! Kur to vārstiņu meklēt? Tb kur viņš atrodas bmw E36 325? Varbūt te var atrast un iemest linku: http://bmwfans.info/original/E36/Cou/32 ... M/1993/05/" onclick="window.open(this.href);return false; :neka:
Visvairāk tas izpažas kad bākā palikuši ~ 10-20 l degvielas! Taisot vaļā bākas vāciņu - dzirdu un jūtu kā ierauj gaisu bākā caur bākas vāciņa malām!
karlisbe
Post by karlisbe »
freimo wrote:E36 bākā rodas vakums! Zinu, ka ir k-kāds vāstiņš, kas to nepieļauj, bet man šis vārstiņš vizdrīzāk ir kaput! Kur to vārstiņu meklēt? Tb kur viņš atrodas bmw E36 325? Varbūt te var atrast un iemest linku: http://bmwfans.info/original/E36/Cou/32 ... M/1993/05/" onclick="window.open(this.href);return false; :neka:
man ir tas pats, jo mazāk degviela, jo lielāku gaisa daudzumu iesūc + ja gandrīz tukša bāka, auto reizēm mēdz aizrīties
riibeklis
Post by riibeklis »
Lambertino wrote:Ecku vienam no mūsējiem ir vajadzīgs labs elektriķis kurš salabotu elektronisko spidometru :arrow: viewtopic.php?f=27&t=9806&start=100" onclick="window.open(this.href);return false;
29103668
Mārtiņš
VWmotion, audi-style atrodams zem nika MartiņšX
vwmotion.lv :naac:
Meklējos, meklējos un šķiet, ka atradu :roll: detaļa nr 1
http://bmwfans.info/original/E36/Cou/32 ... l-13_0372/" onclick="window.open(this.href);return false;
droši, ka jāskatās kas kur tālāk aiziet zilā truba
Tā takā varētu būt pie vainas :arrow: iespējams, ka viņa tev vienkārši ir k kur uzspiesta. Vajadzētu palīst zem autiņa un pačekot!
Nezinu tās shēmas, bet pieļauju iespēju, ka viņa arī iet uz to bākas ventilācijas bačoku
http://ru.bmwfans.info/original/E36/Cou ... l-16_0315/" onclick="window.open(this.href);return false;
moš vēl var mēģināt noštepselēt to trubu no bačoka nost un iepūst ar k ko viņā :)
rrrainis wrote:Kāds moš zin vai dīzeliem var uzlikt konisko gaisa filtru? :D
Var.
