Tehniska rakstura diskusijas
- Lambertino
Kur lai fiksām dabon šādu trubu?
Diametri - 60 un 70
Reāli vajag prekš Raivja S2. Moš kāds zin kur var visu kitu meklēt
Diametri - 60 un 70
- Lambertino
ebay.co.ukLambertino wrote:Kur lai fiksām dabon šādu trubu?
Diametri - 60 un 70![]()
vieniigi fiksaak par paaris dienaam nebuus!
palasiijos par understeer nobeigshanu sheit
http://www.pistonheads.com/gassing/topi ... 0&f=71&h=0
wtf ir bumpsteer un Antilift kit ?cpas - you need to accept that understeer is built in at the factory with the bumpsteer they include as a default characteristic (like nearly all manufacturers these days).
I've spent 8 years (and way too much money ) messing about with my classic to get it the way I like it. I would recommend approaching it in the order;
Decent rubber all round (no point scrimping)
Proper geometry set-up (Prodrive setting are better than std, but people like PowerStation or TSL will do you custom settings with more castor)
Bumpsteer removal
Uprated ARBs/bushes/droplinks
Antilift kit
Eibach sports springs, or if affordable, coilovers with adjustable platforms (I use ASTs currently)
I would suggest getting camber bolts fitted so that you have proper adjustability on the rears.
Moš kkas no šī palīdz:DeeCee wrote:palasiijos par understeer nobeigshanu sheit
Bumpsteer removal
Antilift kit
Definitions of Bump Steer:
* A steering effect resulting from toe or camber changes as the suspension moves up and down.
http://www.tireboys.com/expert_lexicon.htm
* The change in a tire's camber and toe-out caused by hitting bumps. In incorrectly lowered trucks it may occur.
http://www.jcscoops.com/faq/definitions.php
* Also called toe steer, bump steer is the change in toe-in as the suspension moves through its full range of travel; some change is unavoidable due ...
http://www.motortrend.com/features/arch ... index.html
* The ill-effect a fully compressed damper has on steering through turns. Referred to as such because often times when a damper is fully compressed, it is against its bump stop. When this point is reached, neither the damper nor the spring can do it’s job, usually causing loss of grip. ...
users.zoominternet.net/~tworx7s/Auto%20 ... ssary.html
* Bump Steer is the term for the tendency of a wheel to steer as it moves upwards into jounce. It is typically measured in degrees per metre or ...
en.wikipedia.org/wiki/Bump Steer
- Lambertino
Ecku vienam no mūsējiem ir vajadzīgs labs elektriķis kurš salabotu elektronisko spidometru
viewtopic.php?f=27&t=9806&start=100" onclick="window.open(this.href);return false;
Nav kādam padomā, kāds tiešām labs elektriķis kurš saprot ko dara, nevis var salodēt tikai vadiņus kopā un saslēgt spuldzītes virnē!
Respektīvi vajadzīgs elektriķis ar gudru galvu
E36 bākā rodas vakums! Zinu, ka ir k-kāds vāstiņš, kas to nepieļauj, bet man šis vārstiņš vizdrīzāk ir kaput! Kur to vārstiņu meklēt? Tb kur viņš atrodas bmw E36 325? Varbūt te var atrast un iemest linku: http://bmwfans.info/original/E36/Cou/32 ... M/1993/05/" onclick="window.open(this.href);return false; :neka:
Visvairāk tas izpažas kad bākā palikuši ~ 10-20 l degvielas! Taisot vaļā bākas vāciņu - dzirdu un jūtu kā ierauj gaisu bākā caur bākas vāciņa malām!
man ir tas pats, jo mazāk degviela, jo lielāku gaisa daudzumu iesūc + ja gandrīz tukša bāka, auto reizēm mēdz aizrītiesfreimo wrote:E36 bākā rodas vakums! Zinu, ka ir k-kāds vāstiņš, kas to nepieļauj, bet man šis vārstiņš vizdrīzāk ir kaput! Kur to vārstiņu meklēt? Tb kur viņš atrodas bmw E36 325? Varbūt te var atrast un iemest linku: http://bmwfans.info/original/E36/Cou/32 ... M/1993/05/" onclick="window.open(this.href);return false; :neka:
- riibeklis
29103668Lambertino wrote:Ecku vienam no mūsējiem ir vajadzīgs labs elektriķis kurš salabotu elektronisko spidometruviewtopic.php?f=27&t=9806&start=100" onclick="window.open(this.href);return false;
Mārtiņš
VWmotion, audi-style atrodams zem nika MartiņšX
vwmotion.lv
Meklējos, meklējos un šķiet, ka atradumpb wrote:man ir tas pats, jo mazāk degviela, jo lielāku gaisa daudzumu iesūc + ja gandrīz tukša bāka, auto reizēm mēdz aizrītiesfreimo wrote:E36 bākā rodas vakums! Zinu, ka ir k-kāds vāstiņš, kas to nepieļauj, bet man šis vārstiņš vizdrīzāk ir kaput! Kur to vārstiņu meklēt? Tb kur viņš atrodas bmw E36 325? Varbūt te var atrast un iemest linku: http://bmwfans.info/original/E36/Cou/32 ... M/1993/05/" onclick="window.open(this.href);return false; :neka:
http://bmwfans.info/original/E36/Cou/32 ... l-13_0372/" onclick="window.open(this.href);return false;
- Lambertino
droši, ka jāskatās kas kur tālāk aiziet zilā truba
Tā takā varētu būt pie vainas
iespējams, ka viņa tev vienkārši ir k kur uzspiesta. Vajadzētu palīst zem autiņa un pačekot!
Nezinu tās shēmas, bet pieļauju iespēju, ka viņa arī iet uz to bākas ventilācijas bačoku
http://ru.bmwfans.info/original/E36/Cou ... l-16_0315/" onclick="window.open(this.href);return false;
moš vēl var mēģināt noštepselēt to trubu no bačoka nost un iepūst ar k ko viņā
