Pirkt/Pārdot VI
Re: Pirkt/Pārdot VI
Tākā šrotos atrast ir grūti,tad nopirkšu vienu vai četrus saab 9000 2.3turbo smidzinatājus Lucas ražojums D5162EA.
Vai arī pārdošu piecus tādus smidzinātājus par 80Eur.
Tādi kā bildē
PM vai 2968967pieci
Tādi kā bildē
PM vai 2968967pieci
Re: Pirkt/Pārdot VI
Pārdodu pastūzi Soundstream PCA5.540
Specifications:
No. OF CHANNELS: 5OUTPUT (watts):RMS @ 4 Ohms 60x4, 110x1RMS @ 2 Ohms 100x4, 180x1RMS @ 4 Ohm Mono 180x2, 180x1T.H.D.: 0.02%FREQ. RESPONSE (Hz): 10 - 30kSIGNAL TO NOISE RATIO: >97dBDAMPING FACTOR: >200INPUT SENSITVITY: 0.5 - 4.0VCROSOVER SLOPES: 12dBCROSSOVER FREQUENCY: High-Pass(Hz) 50 - 600Low-Pass(Hz) 50 - 150SUBWOFFER EQ: 0 - 18dBSUBWOOFER EQ FREQ. (Hz) : 40 - 120DIMENSIONS (INCHES): 9.5x2.5x18.0Fully regulated MOSFET power suppliesPWM circuitryTri-guard amplifier protectionIDI (Intelligent Distress Indicator) gives a visual indication of the amplifiers protection statusPlatinum RCA inputs and outputsLine OutputsBi-linear selectable crossovers for inputs and outputs (Hi/Full/Low)Continuously variable high and low-pass crossoversVariable subwoofer equalizerPhase inversion switch (0 - 180)OEM floating ground inputPlatinum 4-gauge power connectorsTri-mode operationOptional Remote Bass Control (EGA)
Cena 100 eiro. Atrodas Liepājā. PM vai 28203132
Specifications:
- Foxijs
Re: Pirkt/Pārdot VI
Dodiet LABU E36 BOSCH kreiso lampu, vai tikai stiklu!
Meklēju arī priekšējo kreiso spārnu no compact/sedan/touring labu!
Re: Pirkt/Pārdot VI
Interesē m50 bezvanosa vienmasas spararats ar sajūgu
pm
pm
BMW X3 07'
Re: Pirkt/Pārdot VI
Pārdodu Pirelli winter sport - 225.55.r17 - ap 7 mm
Komplekts 100 eur
Pārdodu r15 195.50 2x labas m+S riepas 6 mm - 40 eur
Pārdodu goodyear 185.60.15 - ap 8 mm - komplekts 90 eur -teicamas riepas
Pārdodu teicamus r21 komplektus ap 6-7 mm 160 eur 4x
Pārdodu Mercedes Sprinter / Vito -Diskus sabortētus ar labām ziemas riepām +- 8 mm
195/65r16c -140 eur
Pārdodu Porche 928 compotition s4 diskus ar visiem spiediena sensoriem un visiem vāciņiem 8j un 9j 399 eur
22348022 tel
Pārdodu bmw dzelzs diskus 5sērijas ar kalpakiem teicamā stāvoklī platie 5x120 50 eur 22348022
Pārdodu labas 5x112 x 17 AMG Diskus - Diski labā stāvoklī dažāda platuma, aizmugurējie platāki ar mazu plauktiņu un priekšējie diski šaurāki ja nemaldos 7, 5 un 8, 5 j, 299eur vairāk info pa telefonu 22348022
PĀRDODU - VERTINI CONCAVE (MONACO) Diskus r22 j10.5 un j 9 = 1x jauns disks 730 eur - Diski jālabo un tamdēļ tirgoju 4x pa 550 eur ar 2 norm un 2 nogalinātas riepas
http://www.vertiniwheels.com/Wheels.html" onclick="window.open(this.href);return false;
Komplekts 100 eur
195/65r16c -140 eur
22348022 tel
- Archuks
- BMW
Re: Pirkt/Pārdot VI
No Compacta/Coupe/Limousine?Foxijs wrote:Dodiet LABU E36 BOSCH kreiso lampu, vai tikai stiklu!
Re: Pirkt/Pārdot VI
Archuks wrote:No Compacta/Coupe/Limousine?Foxijs wrote:Dodiet LABU E36 BOSCH kreiso lampu, vai tikai stiklu!
atkārtošosCOMPACT LIGHTS ARE DIFFERENT
you can use a bosch, zkw, or depo unit on the compact BUT YOU WILL NEED TO WORK OUT THE WIRING !!
some sets are sold with the intention of fitment to ti´s.. Please check with the supplier BEFORE payment.
I get many compact owners ringing me distressed that their lights dont fit, and what is wrong..
so, for the penultimate rundown, listen up..
Compact (Hella) lights fit only compacts
Bosch / ZKW / depo or comparible fit ALL models, (Compacts need extra wiring to fit)
Front indicator / markers = SEDAN / TOURING / COMPACT... do not use COUPE or CAB as they do not fit
Side markers are year definative. Models BEFORE 9/96 use the larger "black with plastic lense" type. Models after use the smaller "all plastic" versions.
Rear lights are Ti / Compact only .
there is no such thing as "318ti" specific, as the compact range spans from 316 to 323
Foxijam un Tev, tas, protams, šķiet bezsakars un bullshits, taču tas lielākoties ir tāpēc, ka praktiskais latvietis jau gadus desmit atpakaļ ir nospļāvies un samuķijis "parasto" lukturu štekerus, tāpēc 4 no 5 kompaktiem viss ir tāpat kā pārējiem.
Korpuss tāds pats, true
P.S. - es zinu, ka šis ir classic joks, bet nu nemaldināsim cilvēkus
- atkarigais
Re: Pirkt/Pārdot VI
Pārdodu Honda šortshifter!
80 eur
Pārdodu jaunu iepakojumā BOSCH 0 580 464 126 sūkni.
50 eur
Mob. 22000771
Der šadiem auto.
https://www.trodo.lv/degvielas-suknis-b ... 80-464-126" onclick="window.open(this.href);return false;
80 eur
50 eur
Mob. 22000771
Der šadiem auto.
